Outside Surface Breaks
If you have a plate that has a cutout on the outside do you dimension with a "2X" in front of the dimension? Or because its an outside surface it is assumed to be the same dimension across to both surfaces.
RE: Outside Surface Breaks
In this case, per ASME 14.5M-1994 yes the dimensions apply all through the part, no need for a 2X or to dimension on both sides of the plate.
You may get a better response if you clarify your question, also forum1103: Drafting Standards, GD&T & Tolerance Analysis may be a better venue for such quesions in future.
If you do post this question there either redflag this one or at least put a link to this one over there.
KENAT,
Have you reminded yourself of FAQ731-376: Eng-Tips.com Forum Policies recently, or taken a look at http://eng-tips.com/market.cfm?
KENAT,
