Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...You have made an incredible site which is truly a great help to me in solving problems. A tip of my hat to you!..."
Geography
Correctly Specifying ZINC PLATE ASTM-B633Helpful Member!
KENAT (Mechanical)
22 Oct 08 12:43
Not sure this is the best forum for this question but a search of this site for 'zinc plate' showed posts in many forums with no obvious favourite.
I have an engineer that needs a corrosion/protective treatment for a steel part.  I've suggested zinc plate, it's in a fairly benign environment but may see some occasional slight wear/abbrasion.  It needs to be ROHS compliant, so no hexavalent chromium in the I've done a bunch of google searches and arrived at the below.
ZINC PLATE ASTM-B633 Fe/Zn 8 (Type III, SC 2, .0003-.0005 THICK, CLEAR) ROHS COMPLIANT.  DIMENSIONS APPLY AFTER PLATING.
Is this the (a) correct way to designate this finish?
I realize the details in () probably duplicate what's given by the Fe/Zn 8 but I want it to be clear for all users and some of the treatment company sites only listed the type & service condition.
We don't call up much zinc plating so I can't readily justify actually getting the spec at this time.
KENAT,
Have you reminded yourself of FAQ731-376: Eng-Tips.com Forum Policies recently, or taken a look at http://eng-tips.com/market.cfm?
Helpful Member!  CoryPad (Materials)
22 Oct 08 13:23
Typical designation:
ASTM B 633 Fe/Zn 8 Type III SC 2
You don't need the thickness numbers unless you need to limit the maximum thickness (the 8 is 8 micrometers minimum).  You don't need to specify CLEAR since Type III is colorless chromate conversion coating.  ROHS COMPLIANT is intended to restrict the conversion coating to only trivalent chromate rather than hexavalent.  I would state that directly.
Cory
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
KENAT (Mechanical)
22 Oct 08 13:48
Thanks Cory, so the TYPE III & SC2 should be out of the parenthesis then, that's what I couldn't work out from the sites I looked at.
The clear is as much for our receiving department as for the vendor, hence in parenthesis.  On the thickness I do believe we need to limit the max thicknes, .0005 would take it up to the next class which is why I set it as the max value, though arguably then it shouldn't be in ().
I'll change the wording on the Hexavalent/Trivalent/ROHS.  I've never been happy just putting "ROHS" but have been directed to do that before on similar notes.
Thanks a lot.
KENAT,
TVP (Materials)
22 Oct 08 15:41
I agree that you should directly specify "trivalent chromate" on the drawing.  "RoHS compliant" is essentially meaningless if there is no reference to a standard.  ASTM B 633 was created a number of years ago, and therefore has not incorporated anything related to reportable/restricted materials, RoHS, etc.
KENAT (Mechanical)
22 Oct 08 16:07
ZINC PLATE ASTM-B633 Fe/Zn 8 Type III SC 2 (.0003-.0005 THICK, CLEAR).  FINISHED ARTICLE TO BE ROHS COMPLIANT, NO HEXAVALENT CHROMIUM TO BE USED IN CONVERSION COATING.  DIMENSIONS APPLY AFTER PLATING.
Updated wording, I'm uncomfortable explicitly saying use trivalent in case they come up with something else, however I have explicitly forbiddien hexavelant which I understand to the be trouble maker.  TVP that's exactly the reason I don't like just saying "ROHS", it doesn't explicitly invoke a standard.  Plus China ROHS is slightly different from EU ROHS legislation etc.
KENAT,
Close Box
Join Eng-Tips® Today!
Join Us             Close
