Flat Heads with stiffeners
Hello All,
I would like to know if there is a section in the ASME VIII-1 which deals with flat circular heads with a spoke pattern of stiffeners. I have not been able to find it, unless maybe I can adapt the section on braced and stayed surfaces (UG-47), but I'm not sure how to do that either. Any help would be greatly appreciated.
F.Y.I. The head is 108" diameter, 0.5" thick SA-36, the eight stiffeners are equally spaced every 45 degrees. There is a 14" nozzle centered in the head which the stiffeners radiate out from and also a 20" nozzle approximately 30" out from the center of the head in between stiffeners. The stiffeners are 3/16" X 3" X 4" SA-500 rectangular tube.
Thanks in advance,
David
RE: Flat Heads with stiffeners
I'm not aware of any rules in Division 1.  You're stuck with U-2(g).
Hi NewMechE.
ASME Section VIII Div.1 does not cover this. U-2(g) would apply.
Also have a look this previous forum discussion... thread794-93914: Reinforcement of flat heads
