#8x3 screw. Pull out strength
Does any body have a freeware or spread sheet per ACI 318 to find out the pull out strength of #8 screw embedded 1.5" in the concrete. Also what will be the diameter for #8 screw?
RE: #8x3 screw. Pull out strength
I made it for my company - it took about 60 hours to put together. It does a full bolt group analysis (for eccentric loads), and even has a 40 page handout complete with examples.
If you post your info I can help you out.
Never, but never question engineer's judgement
