Probe Problem
Probe Problem
Probe Problem
I'm having problems with my self-built measuring device.
The input stage looks like this:
  1V  ------3M6-----------n.inv. amplifier x1,6------- 1V
    1,125M        5M4
    GND             GND
When I connect a x1/x10 probe I get with 1V/10V applied to the tip 1V +-3mV at the output of the amp.
x1/x10 probe:
     <-------9M---------->
         |__--____|
When I connect a x10/x100 probe I get with 10V at the tip and x10-range 0,987V?
x10/x100 probe (only x10 range shown):
     <----4,49M--------->
                      0,969M
                     GND
Why are the results so different?
RE: Probe Problem
Hello again,
I've almost solved my problem smile
The 987mV is exactly the calculated result for the x10/x100 probe with 1MOhm input resistance.
To get 1000mV the 969k should be 976k or the 4,494M a little bit lower.
I don't know the real values, does anyone?
My biggest problem is:
Can I change the probe values by opening it without destruction?
And who delivers x10/x100 probes?
Thank you
