exporting data from ansys
i would like to export data from a Path, into notepad.  i can't find from the path operations menu which is the command. any help please?
RE: exporting data from ansys
In GUI:
List -> results -> path data -> file  -> save as..
In script:
/OUTPUT,filename,extension,  ! redirects output to file
PRPATH,_UX,_UY               ! prints path data
/OUTPUT                      ! resets output redirection
but both solutions result in text file divided into pages.
The other way is to save values from all path points to a variable and export them into file:
*CFOPEN,filename,ext,,APPEND
*do,k,1,path_division
PSEL,itemname,pathname
*get,variable,PATH,0,ITEM,itemname,pathpt,k
*end
*vwrite,variable
%f
thank you izyk
