Pump Selection Questions
2 questions in relation to pump selection:
1. For inline pumps should suction and discharge connections be line size, or is it ok for the pump to have a smaller connection than the pipes it connects too?
2. What is the best speed (rpm) to select pumps at?
RE: Pump Selection Questions
Nothing like the best speed. High speed pumps are smaller in size but life is shorter.
Joe Lambert
http://www.control-associates.com/
Pump inlet and outlet sizes are almost always smaller than the pipe in which it's mounted for a lot of reasons.
