What is a choke plant
What is a "choke plant" and how does it work?
thanks
thanks
RE: What is a choke plant
I won't get into the details about process economics and when you would or wouldn't use this type of technology, but there is a helpful article in Vol 2 of the John M Campebell Gas Conditioning and Processing handbooks.
2) Application shall not over cricondense bar , normally when gas plant 40 bar<Pressure<90 bar system
3) After JT valve you may need LTCS pressure vesel due to that area always link to blow down system ( low temperatur carbon steel) since the temperature is low after J-T effect.
4)piping carbon steel can stand -29 C so no problem. below that medium alloy/stainless shall be use up to -45 C.
5) Chock plant/J-T can work if gas before chock has pre-cooling system use the maulti stream heat exchanger by use its F/E (fee/effluent) and after JT the LTS ( low temperature separator will reject liquid.
6) Normall J-T reject only rough composition/heavy end such as C5+ 90% but not easy to reject C3+ expect 20-30% ( which should use other means such as mechanica C3 refrigeartion)
