Drafting Dimension Default Settings
Would appreciate much is someone could tell me how to set
the dimension default settings to my liking?
Dimension text size, text type, arrow type, etc.
RE: Drafting Dimension Default Settings
You have to start catia in admin mode and change the standard, think you can even go at the xml file directly if you know what you are doing. Check the documentation, there are some detailed exampels, you have to add -admin switch I think to the start icon.
