Solidworks API help - saving a part
Hey guys,
Can anyone tell me why this code is not saving my part?
pDirectory = "M:\Solidworks\Tooling\Inspect\" & tooltbx.Text & "\" & tooltbx.Text & ".sldprt"
If MsgBox("Save as " & pDirectory & "?", vbOKCancel, "Confirm Save") = vbOK Then
    Part.Extension.SaveAs pDirectory, 0, 2, Nothing, longstatus, longwarnings
    If MsgBox("Make a drawing?", vbOKCancel, "Create Drawing?") = vbCancel Then
        End
    End If
Else
    Exit Sub
End If
RE: Solidworks API help - saving a part
Hey, guy!
Can you tell us what sort of thing actually does happen?
-handleman, CSWP (The new, easy test)
I figured it out. As is, the code does absolutely nothing. I changed the save command and added some code that created the appropriate folder if it does not exist and that solved my problems. Here is that code if you were wondering.
FOLDER = "M:\Solidworks\Tooling\Inspect\" & tooltbx.Text
Set FSO = CreateObject("Scripting.FileSystemObject")
If Not FSO.FolderExists(FOLDER) Then
    FSO.createFolder (FOLDER)
End If
pDirectory = "M:\Solidworks\Tooling\Inspect\" & tooltbx.Text & "\" & tooltbx.Text & ".SLDPRT"
    Part.SaveAs2 pDirectory, 0, False, False
        End
    End If
Else
    Exit Sub
End If
