IBC 2006, ASD allowed for Foundation safety check???
I can see in IBC 2003, 1616.1, IT CLEARLY SAYS "ASD is permitted to evaluate sliding, overturning and soil bearing ..."
However, I could not find such sentence in IBC 2006. Did I miss something??
RE: IBC 2006, ASD allowed for Foundation safety check???
I guess what I am trying to find out is that:
I understand that ASD is what we used in practice for FTG safety check. However, I would like to find a standing point from the code IBC 2006 where it says clearly that ASD is what we should use. I can find it in 2003 not in 2006
It's there- third paragraph of 1616.1, P. 354.
1804.1 Design. The presumptive load-bearing values provided in Table 1804.2 shall be used with the allowable stress design load combinations specified in Section 1605.3.
Don Phillips
http://worthingtonengineering.com
JStephen,
There is no 1616.1 in 2006 version. I guess you mean in 2003, as I mentioned.
DonPhillips,
yes this is helpful but it is not clearly stated.
"There is no 1616.1 in 2006 version."
Oops.  I think I pulled out the 2000 version rather than the 2006 version.  Never mind!
