Surface Splitting
Surface Splitting
Surface Splitting
I would like to add draft to a body.
What would be the procedure to split the
surface on the body to add draft?
Thanks in advance.
RE: Surface Splitting
Draft both side directly on the solid, hit the more button on "draft" feature window and there you will find "draft both sides"
thanks much azrael!
