ASTM D 341 chart representation
hi everyone,
do someone know about a program to draw the loglog viscosity followed in this code??? excell does not allow a loglog draft.
thanks in advanced
RE: ASTM D 341 chart representation
Excel can display graphs with logarithmic scales on both axes.  Are you entering negative numbers for temperature?  Change to Kelvins.
You could also download the graph paper generators at http://www.printfreegraphpaper.com/ and plot the 40/500C and 100OC data and draw a straight line fit as per the ASTM D341 directions (I seem to recall that there are examples in the standard)
JMW
www.ViscoAnalyser.com
