Controlling finish on drawings.
Hi.
We are applying GD&T to our drawings to place controls on machining of our products so that the expectations from any subcontractor meet those unwritten expectations of our own shop and selected managed contractors.
This has been a learning curve and surprisingly the subcontractors have not questioned the change to GD&T on the drawings.
Where we struggle at present is in how to apply control of the visual appearance on the drawings. The products are bright nickel plated or electro-polished stainless steel and visual appearance is significant. The attachment link (700kB jpg)shows some images of finishes, acceptable and unacceptable. The unacceptable finishes in the images in fact have a smaller Ra roughness but it is the non-uniform pattern that is not acceptable. We don't wish to introduce additional cost of specifying grinding or polishing if it is unnecessary.
Can anyone suggest a means of applying this information to a drawing, would it require reference to say this link or another means of specification such as a standard.
steve
steve
RE: Controlling finish on drawings.
http:/
Sorry, can't find better at the moment.
-handleman, CSWP (The new, easy test)
Finish would be, for example, 'anodize'.
Roughness would be the surface itself.
A lot of people/companies call it 'surface finish'.
http://ww
http://www.engineersedge.com/surface_finish.htm
Chris
SolidWorks/PDMWorks 08 3.1
AutoCAD 08
ctopher's home (updated Aug 5, 2008)
ctopher's blog
SolidWorks Legion
Finish specification lay lines are described in the ever popular Machinery's Handbook.
JHG
At what point would the circular lay lines of a face mill become perpendicular as there does not seem to be a symbol for this lay.
When I can accept 3 lay line styles, would I put all 3 in the finish symbol check mark (perpendicular, circular and longitudinal)
steve
Chris
AutoCAD 08
ctopher's blog
SolidWorks Legion
