Need Ti-6Al-4V seamless tubing
I need a small quantity (~ 1 m) of Ti-6Al-4V seamless tubing. The size would be near 1" schedule 40 (1.315" OD x 1.049" ID); the size could be somewhat smaller or larger.
I found a company that could supply this in Grade 2 but not Ti-6Al-4V. Any suggestions?
Don Culp
Don Culp
RE: Need Ti-6Al-4V seamless tubing
http://www.alloymetalsinc.com/tubing.php
Plymouth Tube
http://www.snappymaterials.com/titanium-tubing.php
The reason that the CP grades are readily available is that they are used in the chemical process industry were 6-4 is mainly a structural material where weight saving are important.
Despite their web sites, Alloy Metals and Snappy Metals no longer handle Ti tubing or pipe. Any other suggestions?
Don Culp
Good Luck
http://www.ticotitanium.com/pipe.php
http:/
Plymouth Tube
