Renaming Mirror components
I want to save a copy of a component and its mirror. How do I change the mirror to reference the new component name?
Matthew
RE: Renaming Mirror components
I'm not sure I follow.  Did you use Derive Component with Mirror option to create the mirrored part?
Not the most elegant solution, but I think you could...
-Close all files
-Temporarily rename the original component
-Open the copied mirror component. Re-map it when prompted.
-Save and Close.
-Don't forget to rename the original component back to the correct name.
Ken
