how i can mondel a rope?
i want to fix a rope on two walls. then i want to put one handle one odject on this rope and mesure the sag and the sureface presure on the odject.
RE: how i can mondel a rope?
you don't suposedly need Ansys to do that.
i want the sag to be less than a value. so i must add some pretention. The mass is handled by a pipe. I have to edit the shape of the pipe to deform with the same way that rope deforms. In this case the surface pressure is the same in the whole pipe.
Nothing you can't do analytically.
Of course, it MAY be faster with FEM, BUT... you have to have a software with an appropriate element formulation (tension-only link). Don't even try to model the rope in 3D with solid FE elements...
