Modeling tubes, underhood etc...
I've got a general question regarding modeling tubes.. such as A/C lines, hoses etc. Would one begin at 0,0,0 and create an upper level asy and constrain in car position and begin modeling in car that way? Also, for tubes and etc, I think GSD would be the best way to get guide curves for a multi-section solid???
Just curious...
Just curious...
RE: Modeling tubes, underhood etc...
- GSD Swept surface (easier than Multi-Section)
- Part Design Rib
- Tubing workbench
Working with car coordinates makes sense. Might want to use External References (contextual links) to copy points and lines from parts the tubes are being attached to.
Thanks for all the replies...
http://www
Of course you can create your own PowerCopy.
And you can mix toolbars from one workbench to another if you have the necessary license.
Fernando
