large rotation of hinged rigid beam
My new workplace just has linear FEA software (for now), so can anyone help me out by running VM40 (w ww.kxcad.n et/ansys/A NSYS/ansys help/Hlp_V _VM40.html) with and without NLGEOM,ON to determine the minimum rotation for which the nonlinear and linear solutions significantly differ? Thanks for any assistance with this urgent matter!
RE: large rotation of hinged rigid beam
just a small premise: "small displacements" hypothesis is the hypothesis under which the sinus of a dimension can be approximated by the dimension itsels: sin(alfa) = alfa.
So, for example: is your rigid beam rotating of more than some tenths of degrees (some thousandths of radians)? If NO, then small displacements is OK; if YES, large displacements is necessary OR you know you will use small-displacements hypothesis with larger and larger error... It's up to you.
The large deflection solution for cantilever beams (htt
I would think, though, the condition for a difference between nonlinear and linear solutions is problem specific. That is, the sine approximation indicates no large deflection of a cantilever beam but maybe isn't an indicator of no large rotation of a hinged rigid beam. This would be easy to check if someone can run VM40 with and without NLGEOM,ON for 17.5 deg rotation...
