Solidworks Performance Question
I have a PC with Windows XP 64 on it and solidworks x64 2008. My pc has 4gb ram in it and when I run a benchmark, it takes about 180 seconds total(I/O about 55 sec.). If I keep everything the same, but use 8gb ram the benchmark runs the exact time. My I/O, CPU, GPU are all virtually identical to 4gb test. Why isn't it making a difference?
RE: Solidworks Performance Question
It probably won't help, but try setting the Virtual Memory to the recommended minimum, or even zero.
SolidWorks is CPU bound, if you want more speed you want to get a faster CPU.
CPU = speed
x64 = more memory allocation
Cheers,
Anna Wood
SW2008 SP4.0, Windows Vista SP1
IBM ThinkPad T61p, T7800, FX570M, 4 gigs of RAM
http://designsmarter.typepad.com/solidmuse
http://www.phxswug.com
Joel C. Warnke
Mechanical Designer &
Infrastructure Technician
Integrity Design & Mfg. Inc.
www.integritydesignmfg.com
Solidworks x64 2008 SP5.0
Windows XP Professional x64
Nvidia Quadro FX 3700 512mb GPU
AMD Athlon X2 FX 6400+ CPU
4GB Corsair pc2-6400 DDR2 800mhz RAM
WD Velociraptor 10,000rpm SATA HD
Motherboard M2N-SLI
GPU OC (2
Rob Rodriguez CSWP
www.axiscadsolutions.com
www.robrodriguez.com
http://designsmarter.typepad.com/rob_rodriguez/
Eastern Region SWUGN Representative www.swugn.org www.nvtswug.com
SW 2007 SP 2.0
You do not have a problem with memory. It is in the choice of CPU.
Cheers,
Anna Wood
