How to delete an Array component?
I have created an array in an assembly with a couple of simple parts. When I go to delete any of these parts I get the following message-"Attempt to delete an array master component failed." Anybody have any ideas on how to get these parts deleted?
RE: How to delete an Array component?
John R. Baker, P.E.
Product 'Evangelist'
NX Design
Siemens PLM Software Inc.
Cypress, CA
http://www.siemens.com/plm
Worked great, thanks.
I have also a question about the component array. First I create a component A in my assembly and later I create a component array from component A. When the component A modified the component array is not regenerated, and it is not followed the changing. Component A is positioned unconstrained (e.g. linked part). What is the good way? Do I create the component array only from constrained component?
That being said, editing or replacing the original component will not cause the other members of the component array to update. If you wish to do something like replace all of the components of any array, SELECT all of before you perform the 'Substitution'.
John R. Baker, P.E.
NX Design
Cypress, CA
