edge curve offset to surface
Cheers everyone,
I'm using NX5.0.3.2
For sure these command exist because I used these on NX3 before. I just cant find it on NX5 or I maybe forget the command.(you have a surface, try to pick the egde to offset on its face surface at certain distance).
Thanks for your help.
RE: edge curve offset to surface
Try INSERT - CURVE FROM CURVE - OFFSET IN FACE
