Diametral Interference
What is the meaning of diametral interference between two round components?
RE: Diametral Interference
By design... press fit.
By stack analysis... lack of fit or clearance due to tolerance or tolerance accumulation.
By measurement... either a bad design or bad product.
It means that the shaft is bigger than the hole, as per one of PaulJackson's suggestions, above.
JHG
It means that the shaft is bigger than the hole, as per drawoh's response above.
Paul
