Slow performance when regenerating instances
I am currently modeling a heatsink (pin array, ~1500 .040 pins) using a combination of rectancular and circular arrays. The problem I am facing is that it takes 10 min to regenerate my part when I change something.
Is there a way to speed up the regeneration process? Or only have UG regenerate parts that changed instead of the whole part?
-Paul
-Paul
RE: Slow performance when regenerating instances
If you're using NX-5 you might do better with instanced features than arrays.
Cheers
Hudson
NX Version: NX4
Command I am using: Insert==>Associative copy==>instance==>circular array
Is there a better way to make a pattern?
John R. Baker, P.E.
Product 'Evangelist'
NX Design
Siemens PLM Software Inc.
Cypress, CA
http://www.siemens.com/plm
Perhaps using Pattern Face in NX-4 may be more efficient than a feature array. You still find yourself creating rows and circular patterns but the whole system seems to be quicker and neater in the feature tree.
Cheers
Hudson
