Flipping mate dimension in Animator?
Hi
I am trying to make an animation of a rotating part in solidworks animator. I need it to rotate clockwise for some angle, stop, and then rotate counter-clockwise. I am using an angle mate to rotate it but I don't see any way of having it change direction (flipping dimension). I also tried using 2 of the same mates with opposite dimension directions but then I get some warnings and can't make it rotate at all. Is there any way to do this?
RE: Flipping mate dimension in Animator?
To work around this, draw a sketch that will indicate the angle you need to "tag" with your rotated part, and perhaps another line that will indicate your return angle. It's a hack, but it will deliver what you're looking for with the least amount of hair loss from the Animator bugs (there are many more such bugs, by the way).
Jeff Mowry
www.industrialdesignhaus.com
A people who value security over freedom will soon find they have neither.
