BC on discrete rigid body
i am working on metal forming simulation and i've have some trouble with boundary conditions of tooling (a discrete rigid bidy with a refebrence point).
When job is running, this warning occure :
***WARNING: NODE SET ASSEMBLY_PART-2-1_PART-2-1-REFPT_ HAS NO MEMBERS AND WILL BE IGNORED.  NODES DEFINED IN THIS SET MAY HAVE BEEN DELETED BECAUSE THEY WERE NOT CONNECTED TO ANY ELEMENTS.
thus, i've got this error :
 ***ERROR: NODE SET ASSEMBLY__PICKEDSET10 HAS NOT BEEN DEFINED
***ERROR: A BOUNDARY CONDITION HAS BEEN  SPECIFIED ON NODE SET ASSEMBLY__PICKEDSET10 BUT THIS NODE  SET IS NOT ACTIVE IN THE MODEL.
can anyone help me?
Thank's
RE: BC on discrete rigid body
bop07,
If you look in the message file, it will also show you the boundary condition for which this message is meant. This will give you an idea about which bc is involved. Check that particular boundary condition carefully in your model.
Gurmeet
