How do I copy a worksheet and change its name?
I have some template worksheets in a workbook that I want to copy. The templates names start with "zz" to differentiate them from the other worksheets. I want to copy worksheet named "zzThisworksheet" to "Thisworksheet" and leave the "zzThisworksheet" unchanged. The code below does make the copy called "Thisworksheet" but it also renames "zzThisworksheet" to "zzThisworksheet (2)". Any ideas on how to fix this? (There are other template worksheets that are not visible, so that's why I have that one if statement).
Application.ScreenUpdating = False
For Each Wksht In ThisWorkbook.Worksheets
If Left(Wksht.Name, 2) = "zz" Then
If Wksht.Visible = True Then
L1 = Len(Wksht.Name)
LastSheetName = "Sheet2"
Workbooks(ThisWorkbook.Name).Activate
Workbooks(ThisWorkbook.Name).Worksheets(Wksht.Name).Visible = True
Workbooks(ThisWorkbook.Name).Sheets(Wksht.Name).Activate
Workbooks(ThisWorkbook.Name).Sheets(Wksht.Name).Select
Workbooks(ThisWorkbook.Name).Sheets(Wksht.Name).Copy After:=Workbooks(ThisWorkbook.Name).Sheets("Formato")
Sheets(Wksht.Name).Name = Right(Wksht.Name, L1 - 2)
End If
End If
Next
Application.ScreenUpdating = True
End Sub
End If
End If
Next
End Sub
RE: How do I copy a worksheet and change its name?
CODE
Set LastSheet = ThisWorkbook.Sheets("Formato")
Wksht.Copy After:=LastSheet
Set NewSht = ThisWorkbook.Worksheets(LastSheet.Index + 1)
On Error Resume Next
'if the sheet name exists, Error 1004 gets raised
'abort renaming by resuming execution.
NewSht.Name = Mid(Wksht.Name, 3)
End If
End If
Next
Set Wksht = Nothing
Set NewSht = Nothing
Set LastSheet = Nothing
End Sub
Cheers,
Joerd
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
