Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I signed up to your site to get help with a problem and I am so glad I did. I found the help I needed immediately. Thanks to all who contribute to your site..."
Geography
Graybags (Mechanical)
16 Oct 08 6:51
SW 2008 allows me to create a sectional drawing of a part and exclude any rib features from being sectioned.
When I apply this to a sectional drawing of an assembly containing the part described above - SW crashes every time.
On creating the section SW prompts me to choose rib features/components to exclude from hatching - I expand the drawing view in the feature tree, expand the part component and choose the rib features I wish to exclude.  On clicking OK to the selection SW crashes.
Am I doing something wrong, or can't SW do what I'm asking?
Any help much appreciated.
Graybags
CorBlimeyLimey (Mechanical)
16 Oct 08 7:52
Does SW crash if you select the rib in the graphics area?
cheers
17 Oct 08 9:52
I'm not able to select the rib on the elevation I wish to section - If I try, I exclude the whole component from being sectioned.
17 Oct 08 10:45
Can you post the part and drawing to play with?
cheers
SmuttIII (Mechanical)
2 Nov 08 22:09
Is it possible to remove hatch lines from a rib in a cross-section drawing with SolidWorks 2004?
smcadman (Mechanical)
3 Nov 08 9:17
Is the section view parallel or perpendicular to the rib? Considering SW follows ANSI standards, I'm surprised it hatches the rib.  Ribs and webs are not supposed to be hatched if the section view is parallel to it.  However if the section view is perpendicular to it, it should be shown.
(correct me if I'm wrong, but I'm pretty sure that's the case)
Flores
3 Nov 08 9:35
If I'm remembering correctly, the non-hatching of ribs was only introduced fairly recently (2006 ?)
cheers
Close Box
Join Eng-Tips® Today!
Join Us             Close
