Add Properties to Material Table
Is it possible to add properties to a material table.
I'm not referring to adding another material, or editing existing values like density.
What I want is to add a new property such as "Notes" which could have some other usefull material data.
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
RE: Add Properties to Material Table
AFAIK that's not possible -- they never had thought of that. Each
property has an ID and these are fixed and you can't put in
a new one
dy
The workaround is to add that as a custom property to the part file. Of course, it is part specific and not material specific.
--Scott
http://wertel.eng.pro
request for the specific field(s) you want added.
the name and type should by *any* like we've with custom
properties. The needs for any additional properties that
should go along with a specific material may differ from
company to company.
dy
With so much confusion these days over material standards (particularly BS & EN steel grades) we thought it would be beneficial to add some notes on typical use, bend rads etc.
bc.
Quadro FX4600.
