Omega and OCBF's
Omega and OCBF's
I overheard a conversation reguarding the use of omega in OCBF vs SCBF and hoped someone could confirm/deny/shed greater light on the subject.
For a SCBF the brace is designed for R=6. With omega=2 applied to the connections making the connection design twice as strong as the brace. So a reliability of R=3 appears be the max force necessary to design for.
But an OCBF has a R=3.25* and an omega=2. Applying omega here ostensively enhances the design of the connection to be equivalent to R=1.625 or 2x stronger than the connection of the SCBF!
The conversation I overheard was just that - it is not appropriate to apply omega to an ordinary systems because the reliability is already reduced to minimum levels by the lower R values.
AL
*P.S. (Was an R=3.25>3 selected just so the design would be forced to comply with the special seismic provisions?)
AL
RE: Omega and OCBF's
I don't have my copy here, but from memory the Expected Yield Force is used for SMF, IMF & OMF connection design
