Slab on Grade for a Water Tank
Hey Guys;
I am designing a slab on grade. It is a 22'x 200' concrete slab. I will have several tanks along the concrete pad. Each tank weights approximately 141 kips. This load will be distributed by 4 columns, which will be attached to the tank. Therefore; I will have a maximum concentrated load of around 36k on the slab. I am using the ACI 360R-5, PCA method, but it is mostly for vehicular loading. Any Ideas on how to model the slab.
Thank you.
J.L.P.Q
Thank you.
J.L.P.Q
RE: Slab on Grade for a Water Tank
