Importing into Solidworks from Inventor
I have created the same thread in the "Inventor" forum, but I would like to know if anyone knows what file type I need to save an Inventor drawing in to be able to open/edit it in Solidworks?
RE: Importing into Solidworks from Inventor
SolidWorks can import (not perfectly-formatted) DXF and DWG files.
It can also shows I can import Inventor part files, along with the other standard parasolid, IGES, STEP, etc. but I've not tried Inventor files before.
Jeff Mowry
www.industrialdesignhaus.com
A people who value security over freedom will soon find they have neither.
Jeff Mirisola, CSWP, Certified DriveWorks AE
http://designsmarter.typepad.com/jeffs_blog
Thanks for the help.
-Brian
But Autodesk Inventor 2009 can open Sw files without any problems.(this isn't enablied on Lower Versions) if you open Import panel in AD.INV you can see that the SW files extentions (sldprt,sldasm) added to Inv suport files list.
Notice Inventor won't open SolidWorks drawings either.
-Dustin
Professional Engineer
Certified SolidWorks Professional
Certified COSMOSWorks Designer Specialist
Certified SolidWorks Advanced Sheet Metal Specialist
I would convert the model and recreate the drawing in SolidWorks.
Chris
SolidWorks/PDMWorks 08 3.1
AutoCAD 08
ctopher's home (updated Aug 5, 2008)
ctopher's blog
SolidWorks Legion
Caution you about scale mistakes that can occurred in this method, I have a bad remember about it! there is a part that we just have a Step file format from it, I import this file to SW and prepare a drawing from it with maximum details in geometrical and dimensional tolerances, after producing this part I send that to assembling group, there is a hole at the center of this part that a magnet with 80mm height must be fitted on it, this magnet was grinded to obtain (-+0.01) accurate in height, but when we try to put it in the hole on the part, it fall down deeply, and lost in it, you can imagine my expression on that scene, when I check my drawings I found that the hole height is (120) in the Step file, this mistake can annoy you in file transferring between 3d modeler and FE analyzer too, for exam: you modeler unit system is based in (mm) but the FEA software is on (cm), when you run an analysis on this file all of you results would be wrong! but maybe you couldn't find the error resource because your FE model is 0.01 bigger than your actual model,
can anyone say me how quote is work in this site?where it is?
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of these Forums?
Chris
AutoCAD 08
ctopher's blog
SolidWorks Legion
ctopher,
My hinting is not about you, I say that this type of mistakes can be happen in that method if you don't take care to them! But about Inventor I strongly recommend that use it, it's very interesting , and powerful in modeling, assembling, Dynamical simulations (pro Version), Statically analysis and content center library, it has a wonderful utility to designing of engineering parts such as Shafts, Timing belts, Bolts, clevises pins, brake and etc, you can perform all necessary analysis to designing of each of them,
What do you mean by "10 full pages"?
The Process TGML information is only one page, albeit with a scroll bar. I understand that English is not your first language, but it is a very simple read.
To make a quote simply copy and paste the text you want quoted inside [quote]Copy text here.[/quote]
Gee!!its realy works thanks all!Ok Guys,lets go,
I know. Thanks.
Chris
AutoCAD 08
ctopher's blog
SolidWorks Legion
