Reference file is red
Can anyone tell why a reference file shows up in red text in the reference file manager in Microstation V8?
Thanks.
RE: Reference file is red
I beleive that the ref file has lost its path.  You need to repathit and make sure that you select the save path check box.  Or the ref file may have been moved and it cannot resolve its current path.
That means it is the current selected refence file, that means it could be opened by another application. Maybe another bug or attribute setting. Let you know ASAP.
Namdac
