capture relations
capture relations
I am having the hardest time getting anyone to respond on any forum about captured fits. Does anyone know how to programmatically set a geometry type of a part file to be used in capture fit. i can see using solid edge spy that my document (a nut) has a 'capturerelationshipcount' of 1, and a 'hascapturedrelationships' set to true. But I don't have any idea how to identify which body it's using or for what type of relationship. Does anyone have any idea?
RE: capture relations
I think it can only be done interactivly. The only method
available is (assembly document):
CaptureRelationships(RelationshipCount As Long, RelationshipsToCapture() As Object)
This implies IMHO that a relationship already exists and you
have to specify (in an array) the 3D-relation objects to be captured
dy
Thank you so much for your response. I am fairly new to programming. Could you give me an example line of code for to making this work.
sorry but I've no code snippet that does just that.
dy
IMHO?
holds. Even when it's only one it must be passed to the method
in an array.
dy
This is my only relation applied to my part
Dim objRelNuttoScrew as Solidedge.assembly.axialRelations3d = nothing
objRelNuttoScrew = objReleations3d.addaxial(objReftoConeInNut, objreftocylinderinscrew, false)
This is my attemp at capturing relationship
Dim objB as Solidedge.occurence = nothing
Dim objRelationsforcapture(0) as array
objrelationsforcapture (0) = objRelNuttoScrew
objb.capturerelationships(0, relationshipstocature:= objRelNuttoScrew)
Like I said i'm new to programming:)
