BSTP (British Standard Taper Pipe) Thread Data
Hello. We are in the process of designing a product that requires BSTP (British Standard Taper Pipe) threads. We need to create them in 3D for the tool shop. In searching various  reference sources (including Machinery's Handbook) we can't find a detailed diagram (like NPT data in Machinery's Handbook) that gives concise info on where the threads start. Has anyone out there created BSTP (British Standard Taper Pipe)threads and is willing to share that info?
Thanks for your help.
SW '08 SP 3.0
Dell 380
XP SP 2
RE: BSTP (British Standard Taper Pipe) Thread Data
Synonyms:
ISO taper pipe thread
PT thread
You really need to model threads in 3D for the tool shop?
 Try http://mdmetric.com/tech/thdform3.htm
-handleman, CSWP (The new, easy test)
Thanks to all for your valuable input.
Also, you may find more info by looking up BSPT (British Standard Pipe Taper) rather thand BSTP (British Standard Taper Pipe)
