Parts lists using same assembly on different sheets
I'm having a problem when I have several sheets that use parts lists based on the same assembly. On the main assembly sheet I want the parts list collapsed so I only see subassemblies. However, on other drawing sheets, I want the list expanded so I can see the parts. When I expand the parts list on one of the other sheets, it automatically expands the parts list on my main assembly drawing. A side problem is also created because then my auto bubble feature calls out individual parts instead of the subassembles like I want on the main drawing. Now I work around this by expanding the parts list and making the rows I don't want to see invisible. This doesn't fix my auto bubble problem, because with list expanded, it will only call out individual parts as opposed to subassemblies.
RE: Parts lists using same assembly on different sheets
