HV shunt reactor
HV shunt reactor
Hi all !
I have to review a tender bid submission for a 34.5 kV, 14 MVAr power factor correction capacitor bank, equipped with a shunt reactor tuned to 5th harmonic.
The 3 Ph symmetrical SC in the PCC is aprox. 20 kA/1sec.
The unit is comprised from a capacitor bank (spited unearthed star) in series with the shunt reactor.
The tender specification calls for 3 x single phase shunt reactor, but the Contractor tries to sell a 3 phase shunt reactor (made in Korea).
In my short experience, all HV shunt reactors I've seen in the HV substations are single phase.
I guess, the single phase reactors are easier to manufacture. They could present the advantage of a lower impact against the other reactors, in case of a single phase fault. Probably there are many other pro & cons regarding these two constructive solutions.
I would like to know if indeed 3 phase shunt reactors are used in similar applications like the one I've describe above.
Thank you!
Thank you!
RE: HV shunt reactor
Are these air-core reactors?
A 3-phase air-core reactor is simply 3 single phase units stacked...normally with the center-phase wound in the opposite direction for countering short-circuit forces.
3-phase stacked air-core reactors are typically slightly more expansive than single-phase arrangements due to the insulators normally needing to be strong on the bottom and middle phase.
There is typically little to no difference in the actual coils.
You might be correct, but the comments on 3-phase versus single phase for air-core still hold for series reactors too.
One more point is whether these are oil filled air cored units.In such a case, three phase unit is always better than single phase units.I agree that nowadays trend is for air insulated, air cored, series reactors.
My point on air-core reactors is basically, there really isn't a three-phase reactor, but rather different arrangements of single-phase reactors.
Oil-filled, being iron-core, are of course different.
I agree with you -in air insulated,air cored series reactors there is not much difference between three phase or single phase.If the quality is good user need not worry.
Prc, you right, I have mixed the terms, shunt reactor is not same thing as a serie reactor.
I've never heard of or seen an oil-filled air-core reactor. Why would it need to be oil-filled?
Up until a year ago, I worked for one of the main air-core reactor manufacturers...never ran into something like you describe. Who makes air-core oil-filled units?
Don't have the book. Is it online?
What kind of higher ratings do you mean?
Air core (non oil-filled) series reactors are commonly applied up to 765 kV.
The only time I see oil-filled reactors being used is in shunt applications over 115/138kV or where the inductances are of a level that iron-core designs are needed.
I used to supply even smaller oil filed series reactors.
765 KV series reactor winding in air?What about corona?Why series reactor is required at 765 kV?Can you post details.
When I say higher rated,higher voltage and MVa.In UK ,I understand they have very large series reactors-1000MVAR like.
Technology for air-core (open) reactors has come a long way since the old concrete designs. A 30 MVA air-core (open) reactor is quite common now. Single coil designs up to 300 MVA have been made.
The applications I was involved in at 765 kV were mainly cap bank installs and we supplied the in-rush reactors. Also supplied a few current limiting reactors at that level, as well as one set of very large load balance reactors for balancing/controlling loads on transmission lines.
As for corona, corona rings and special terminal connectors were used of course, but it wasn't an especially difficult issue.
Sorry for replying to an old post, I was only able to login today.
We manufacture Harmonic filtering for the South African Market and almost all of our outdoor PFC applications are with 3 x single phase air core reactors that are stacked vertically. We generally keep the iron core reactors for indoor use as they are IP00 rated.
We offer air core 3phase reactors but in actual fact they are 3 x 1ph reactors with centre coil wound in opposite direction.
The one thing to watch out for with air core over iron core is that there must be no closed loop magnetic steel within the magnetic radius of the reactor - this includes rebar reinforcing in the plinth. This isnt a problem for iron core reactors.
We design and build all of our harmonic filtering reactors. We probably build 95% of them as 3-phase, dry type, iron core. We build single phase iron core also if our customer so specifies.
We also build air core reactors, including those used for harmonic filtering, but prefer to go with dry type, iron core due to the concerns with the magnetic fields of air core reactors. We build shunt reactors in oil-filled pad mount designs only.
This is a very interesting thread. Thank you.
