Photoworks material help
Ok, I am doing a rendering, and I am using stainless steel as the material. But it's just not coming out the way real stainless steel comes out. I'd like to get it as close as possible. Anyone have good techniques, or selection of another material?
RE: Photoworks material help
Start with a single direction light within the indirect light environment you create.
For the material, you'll need to play with the settings available for reflectance, texture, and all that stuff to dial it in. But the top two suggestions are the most important place to start, and work from there to tweak the material to where it should be.
What version are you using?
Jeff Mowry
www.industrialdesignhaus.com
A people who value security over freedom will soon find they have neither.
Check out www.robrodriguez.com for more tips.
Jeff Mirisola, CSWP, Certified DriveWorks AE
http://designsmarter.typepad.com/jeffs_blog
Chris
SolidWorks/PDMWorks 08 3.1
AutoCAD 08
ctopher's home (updated Aug 5, 2008)
ctopher's blog
SolidWorks Legion
Chris
AutoCAD 08
ctopher's blog
SolidWorks Legion
In 2006, you could also create a camera to lend some perspective to your scene, which I'd highly recommend to break up all those parallel lines. 50mm camera is a realistic view to start with. I recommend using a camera over using the perspective view option since it will provide finer adjustment to your view and remain more consistent.
Jeff Mowry
Wasn't there an option to add lighting and click-move them?
Chris
AutoCAD 08
ctopher's blog
SolidWorks Legion
Jeff Mowry
Chris
AutoCAD 08
ctopher's blog
SolidWorks Legion
Rob Rodriguez CSWP
www.axiscadsolutions.com
http://designsmarter.typepad.com/rob_rodriguez/
Eastern Region SWUGN Representative www.swugn.org www.nvtswug.com
SW 2007 SP 2.0
ht
Jeff Mowry
