Cylindricity Should be controlled by perpendicularity?
Is Cylindricity controlled by by perpendicularity?
RE: Cylindricity Should be controlled by perpendicularity?
Joe Tank
Cory
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
I believe in certain situations you may get some control of cylindricity from a perpendicularity call out if working the ASME standards.
forum1103: Drafting Standards, GD&T & Tolerance Analysis may be a better place for future questions like this.
KENAT,
Have you reminded yourself of FAQ731-376: Eng-Tips.com Forum Policies recently, or taken a look at http://eng-tips.com/market.cfm?
If one had perpendicularity of a long hole with a diametrical tolerance zone, it would control the angle of the hole and the straightness of the axis. If, as an example, the perpendicularity is a diametrical tolerance zone of 0.1 mm, one could zero off on the bottom of the hole (centre) and then check the top of the hole. Let's say it was 0.08 mm off perpendicularity. One should also check the middle distance down the hole and let's say this is 0.09 mm. The 0.09 is the result that should be reported and it was caused by the hole axis not being straight.
It does not control size distortion as long as the hole is within tolerances and roundness really doesn't come into this as long as everything meets rule #1 on size.
Dave D.
www.qmsi.ca
When applied to a cylindrical feature of size, Perpendicularity controls the orientation of the cylinder's axis. The cylinder's axis is defined as the axis of its Actual Mating Envelope, and is by definition perfectly straight.
Controlling the orientation of the axis does not control any of the cylinder's form characteristics (circularity, cylindricity, surface line straightness, derived median line straightness). These would be governed by the size tolerance (via Rule #1) or by explicit form controls if present.
Put it this way - a banana could be perpendicular to the floor within 0.001".
Evan Janeshewski
Axymetrix Quality Engineering Inc.
www.axymetrix.ca
KENAT,
When the people fear their government, there is tyranny; when the government fears the people, there is liberty. - Thomas Jefferson
