Band/Drum Heater
Band/Drum Heater
I have a 15.5-gallon SS304 drum that has an O.D. of 16.125".
I want to fill it with 10-gallons of 70F water and heat it to 200F using a 120V _____watt band/drum heater.
Like to accomplish this in 1-hour.
Drum is atmospheric pressure.
Can somebody fill in the blank ________watt..??
Thanks.
CW3
Thanks.
CW3
RE: Band/Drum Heater
Mass of water for 15.5 Gallons = Approx. 60 kg
Cp of Water = Approximately 4.187 kJ/kgK
DeltaT = Approx. 72 K
Q= 18 kJ
You want watts so multiply by 1000 to get joules, then divide by 3600 to get J/s (watts).
I get around 5 kW.
I used the program that mcgyvr put up and I get 6kW so I may be a little off.
V
As it happens a heater designed for 4500 watts at 240 volts, which is fairly common on domestic water heaters, will give 1500 watts at 120 volts.
Thanks.
vc66 used 15 gallons (size of the bucket). You only fill the bucket with 10 gallons or water.
V
