calculating rho prime for long-term deflections
This might sound like a silly question, but I have to ask. The question is which b to use when calc'ing rho prime in order to get the long term multiplier for long term concrete deflections.
Let's say you have a concrete T-beam with a flange width of 120" and a stem width of 36". You will get a significantly different rho prime depending which b you use for As/(bd).
I have always used the flange width, but have never had such a big disparity before and needed so much compression steel to cut down the long term deflections so this is the first time I've thought this much about it.
RE: calculating rho prime for long-term deflections
So you'd use the 120" and the area of compression steel at midspan.
