Switching Environments
Hello all,
Any idea why the option to Switch to Sheet Metal (under Applications menu in Part environment) is greyed out.  I have some geometry and have saved the part but cannot switch between environments.
Thanks in advance.
RE: Switching Environments
If you start a model in the part environment you can't switch to the sheet metal environment there is only the other way around that is working.
If you don't want to lose your part then you can insert it as part copy into a sheetmetal. Of course it's only a bandaid :(
Patrick
Ah I see,
Thanks Pat
