Compression only spring (or link?)
I could not achive to model compression only spring whatever I did. I am assinging compression-only springs to area mesh set but I am still seeing some tension force upon area face in my trial models. I have V12 plus version. Therefore I am doing linear analysis. When I choose compression only springs, they do not look like a spring (zig-zag)but looks like brackets (I think this is link). Can you help me to describe linear springs which will not take any tension force in linear analysis. So I'll able to get rid of deleting springs which shows tension in joint reaction result display. Best regards.
RE: Compression only spring (or link?)
The springs can still act linearly in a non-linear analysis
