Vapor Degreaser - Trichloroethylene alternatives
Hi everyone,
I'm currently looking for alternative degreasing technologies for our current TCE vapor degreaser. We are currently using this equipment to clean aero-engine parts (magnesium, stainless steel and aluminum) from light oils (machining cooling oils and fluorescent penetrant dyes used for DPI) as our prep prior plasma spray deposition.
I was wondering if anyone has gone through this path already and might be able to point me towards the right direction.
From what I've seen so far it's either a choice of sticking to the chlorinated solvents (which some might be phased out as well in the next 5-10yrs) or going towards a aqueous cleaning systems (that may or may not be able to effectively clean the parts).We are hoping we can go for the aqueous cleaning systems any inputs?
Cheers,
F.
Cheers,
F.
RE: Vapor Degreaser - Trichloroethylene alternatives
see this article - http://
David
We have also tried to limit the vpor cleaning of componets by the use of hot alkaline ultrasonic baths.
http://www
http:/
