Plate rolling - the LONG way
We are looking at CB&I "Vertical Plate Coke Drum" technology. It's basically the fabrication of a coke drum in the shop or in the field, but instead of rolling rings, they roll plates the "long way" to make vertical sections for the drum. I won't get into all the reasons why this is done. What I want to know is who, particularly in Europe, is able to ROLL or FORM plates the long way to make these sections. We heard Offenhauser used to do it in Houston with 25' wide roll, but we are still researching this.
THANKS FOLKS!
THANKS FOLKS!
RE: Plate rolling - the LONG way
CB&I have four offices in Europe. I presume that you have contacted them? http://www.cbi.com/about/worldwide.offices.aspx
jt
FACCIN:
Thick plate but limited to 13' in the brochure. Evidently they have made larger machines.
Home office is in Italy.
http://www.faccin.com/hav-USA.pdf
Webb Corporation:
Up to 20'2" x 7/8" I assume a low yield material.
http://www.webbcorporation.com/id3.html
vesselfab: I checked with Offy, and they have a press brake that can simulate this, but only up to 1/2" think and 20' long (wide).
unclesyd: Good idea, we'll check into that.
Though we've not unconfirmed, if anyone is intersted we got these leads:
S and T International
Mauriceville, Tx.
Robertson Metal Fabricating
Houston, Tx.
Thanks...
http:
http://www.tspi.biz/plate_rolling.html
Both are limited to 12' rolls. The articles regarding CB&I say they are doing 40' sections.
I talked to somebody that said the technique is to press brake the sections. Mentioned a company in Chattanooga called Austin Energy, but I can't find anything on the net about them.
http://www.atfco.com/forming.html
Most of the companies mentioned by unclesyd have 40+ ft press brakes. TSPI has a 40 footer and AmTank a 50 footer. Hodgson may?? also have 40 ft press brakes. Stars for unclesyd.
Also try Dillinger Hütte GTS and see if they can form the 40 ft plate sections for you.
http://w
According to the print brochure, they have a unit that can press 12.25 meters long, 2 meters wide, and 60 mm thick.
Thanks to all who assisted.
If it's heavy wall you're looking for you should consider mach industrial http://www.machindustrialgroup.com
