Searching for specs ANSI/ASA A21.2 or AWA C102
I am trying to find specs ANSI/ASA A21.2 or AWA C102 for cast iron pipe. This pipe is referenced on a drawing from 1960. Internet searches yield references to the standard but no way to view or purchase. I also searched code websites (ANSI, AWWA, techstreet, IHS) directly with no luck. I'm guessing it has been superseded but I can't find what the new spec would be. Can anyone help? Thanks.
RE: Searching for specs ANSI/ASA A21.2 or AWA C102
Patricia Lougheed
Please see FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
You might want to look for a copy of the Ductile Iron Pipe Research (DIPRA) Association Handbook of Ductile Iron for further information on what is currently available and how it should be used. These materials are still covered by the A-21 group of Standards.
Regards, John.
Another reference describes it similarly as "Specifications for Cast-Iron Pit-Cast Pipe".
[I think incidentally the pit-cast material had target burst tensile strength of 11,000 psi, a modulus of rupture of 30,000 psi, and a secant modulus of elasticity dependent on test methods of say ~ten to fifteen million psi etc.]
