NX6 Assembly Constraints
Is anyone else having problems with the assembly constraints in NX6. When ever i bring in an assembly created in an older version of NX and i convert the constraints i run into issues with the constraints not functioning correctly and i have to pretty much delete all the constraints and start over.
RE: NX6 Assembly Constraints
i have any questions about assebly constraints under NX6.
For example, i build my assembly. Any steps shown bellow.
1. create component A which contains a solid body
2. create another blank component, e.g. B( assemblies --> components --> create new components )
3. Link the solid body from component A.
4. assemble the component C ( assemblies --> components --> add components ), which depends component A & B.
5. modify the solid body in component C
Any unconstrained component positions are changed!
See your example;
unconstrained components: A; B
fully/partially constrained: C
what is the correct solution? Our assembly do not have any unconstrained components? And the new components, which contains any linked geometry, add to assembly constrains creation mothod: FIX?
thanks,
Best Regards,
Rudolf JONAS
Mechanical Engineer
Hungary
I'm intersted in the problem with the constraints
the problem is not clear / can you upload an example asm?
thx
sorry for delay, but I am very busy at present, but as soon as possible I will place the sample assy...
Best Regards,
Rudolf JONAS
Mechanical Engineer
Hungary
