User Subroutine
User Subroutine
User Subroutine
Hi guys,
I'd like to specify the maximum time increment of a step while the step is running. I mean, I'd like to implement a subroutine that after a step increment is finished, some outputs are extracted from the fil, then I perform some calculation with this outputs then on the basis of the results I'd like to impose the time increment of the next step increment inorder to increase or decrease it as a function of the calculation results. Is it possible?
I hope it is clear.
Bye
RE: User Subroutine
UEXTERNALDB : This subroutine is called at the end of every increment. You can call other programs from this.
URDFIL : This reads the file file.
So in principle you can read the fil file and and do some calulcations on the field values. But to set the time increment.? anyone knows?
RE: User Subroutine
Any suggestion guys?
Bye
RE: User Subroutine
Maybe a combination of ABAQUS Scripting Interface(ASI) and RESTART might work. You can use ASI to script model generation/update and to extract data from the .odb files.
RE: User Subroutine
Hi guys,
thanks for the answers.
Actually I'd like to avoid so complicated procedure using restart....therefore at the end of the day no user subroutine for the scope to impose directly the step increment sad
See you
RE: User Subroutine
that's exactly the purpose of the variable DTIME  in the subroutine URDFIL mentioned by guru64.
RE: User Subroutine
Hi potf,
yes u are right. I read only the overview and so I missed that one....always read till the end of the page!!smile
Thanks a lot guys
Bye
