Solidworks 2008 Lockups
I have a increasingly annoying problem with solidworks. Within 10 minutes after starting solidworks everyday it will lockup for up to 20 minutes before it will start working again. I have now started using the task manager to shutdown solidworks when it locks up because it will not always come back on its own and it is too much time to sit and wait for it to hopefully come back. There is no telling when it will lockup. Here are a few examples of times it locks up. After loading solidworks and clicking on the open button, editing features of a part, switching between parts. Has anyone been having a similar problem. I have been cleaning out my temp files about once a week and i don't run the automatic backup. Here are my system specs.
Dell
Intel core 2 Quad CPU Q6000 @ 2.40 Ghz
4096 MB Ram
XP Pro X64 edition
Quadro FX 3500 256MB
Solidworks 2008 X64 bit Version SP4.0
Dell
4096 MB Ram
XP Pro X64 edition
RE: Solidworks 2008 Lockups
-handleman, CSWP (The new, easy test)
It's not a memory problem as I'm running an X64 system with 8 GB of RAM. Nor is it a network problem as I'm working solely off my hard drive.
Jeff Mirisola, CSWP, Certified DriveWorks AE
http://designsmarter.typepad.com/jeffs_blog
Is the Indexing function active?
