Residential Wetland Wastewater Treatment
Dear Colleagues:
I want to treat about 6,500 gallons of residential wastewater that will be produced in a three day period. I need some suggestions for articles on how they do it over in Europe, which I heard they do, how to get a dry climate California County to accept such an unusual idea and how to be allowed to put the effluent on fruit trees in an orchard near the house. The ground is not permeable enough to accept that much water, but the flows will only be that high every once in a while when there are guests for a few days. The rest of the time it will be much lower.
Thanks.
Bicyclemichaela
Thanks.
Bicyclemichaela
RE: Residential Wetland Wastewater Treatment
w
(See page 50)
For the flow that you are estimating, this project will not be economical proposition. You also have to be concerned about the operating costs since you may be required to have a wastewater treatment plant operator to run it.
It is probably not worthwhile to import a system from Europe since everything that you will need is available in the States. In addition, if you try to import some technology and attempt to have it approved by the regulatory agencies, you may end up in a time wasting regulatory dilemma
